misfire after cam install
Old 02-09-2010, 06:15 PM
b4c346's Avatar
Default misfire after cam install
hi,i have a 2001 camaro and just put in a cheater cam , and i have a misfire on #3 cylinder.tried a new plug, wire and coil.what else do i have to check for? thank you.
Old 02-10-2010, 07:13 PM
racecar's Avatar
Pushrod, Rocker arm, valve springs....electrical connection on the injector.
Old 02-10-2010, 08:16 PM
ZL1Killa's Avatar
are you getting anymore misfires at all in any other cylinders? I have a 220/226 cam and when I put it in my computer told me it was misfiring, however driving it above idle resulted in no misfires....turns out for some reason those range of cams (220) tend to have/cause the computer to think its misfiring due to their sensitivity.
change your misfire sensitivity tables at idle & low rpm by some % and problem solved, THAT IS IF you actually DON'T have a misfire problem and have misfires in more than 1 cylinder.... i logged all cylinders doing it, but some more than others at idle
Old 02-11-2010, 11:26 AM
b4c346's Avatar
Thumbs up
a rocker arm backed off.all o.k. now.thanks guy's
Quick Reply: misfire after cam install
