New Clutch Suggestions
I have an 05 GTO and why my clutch is not yet slipping I know that it will be shortly. I also plan on doing heads and cams within the next year or so. If you have any suggestions for a performance clutch I would like to hear them as I am fairly new to the car and the general performance car side of life. Thanks.
The Level 3 Monster is very popular with heads and cam guys. It will hold up to 700hp so it give you some room to grow.
Here is the Level 3 on our web site if you want to read up on it.
http://www.shop.gforce1320.com/produ...&categoryId=21
The Monster clutch packages are a plug and play setup. It comes with everything needed for the install. Very well designed clutch packages.
Thanks
Chris
Thanks
Chris
navygoat, aside from the heads and cams do you have any longer-term power goals. I ask because it's best to install a clutch that can handle your future mods. If you plan to stop with the next set of mods then a Stage 2 or Stage 2+ would be a great option. Of course, you could also opt for a stage 3+ if you plan to go bigger and better in the future. I have privided a link to our webpage specific to these parts below. Take a look and let me know if you have any further questions. Thanks,
http://www.specclutch.com/cars/Pontiac/GTO/2005/Single
Sweet, Thank you guys, I eventually would also like to get a blower but that will be a little while off. I will look those up and figure out which one I will need I am hoping to have a new clutch in by May
