Valve covers? Help!
Valve covers? Help!
I recently bought a set of fabricated aluminum valve covers at a swap meet, after I got them home and began comparing them to the stockers I noticed the stock covers have vacuum lines running to them ( from the TB and back of the intake). The new covers dont have ports for this. Will this cause a problem? If so, how can I fix it?
Hmm. let me know what you do. i may have the same problem soon. if i do i was also thinking of just drilling a hole and welding in a fitting for the hose to go to..
i was thinking about doing one where it it thredded so just drill the hole big enough and put a nut on the inside.. but that could go very wrong if it came loose.. weld in would be the safer bet.
