suspension squeaks alot in cold..
my car has been squeaking alot mostly from the back when say the backend is bouncing some or going over uneven terrain. where are the places located i need to greese and what should i use to lubricate and stop this?
unfortunatly, on a stock suspension setup there arent any grease fittings...you could try spraying WD40 on all the rubber bushings for a temporary fix, or use this as an excuse to get rear lower control arms with greaseable urethane bushings, the panhard rod can squeak as well and can be replaced easily with urethane bushings.
