It connects to the back of the intake manifold...what is it and is it needed...looks to be blocked off already i am thinking after my headers were installed, maybe has to do with the AIR system...thanks
yea that is from my 02...it mounts on the back on the drivers side on the intake manifold...then the line runs along the back and connects to the intake on the rear passenger side...if you have a fast or ls6 intake there will be a port...
just remove the AIR system completely and plug the ac/heater vac line directly to the barb on the back of the intake
Exactly what I did. Go for it. My hvac wasn't working for awhile so I took the intake completely off and found out a rodent ate through this vacuum
line. I was pissed
line. I was pissed
