LTx front brakes to C5 rotor/bracket or LSx rotor?
I have an 94 Formula. I have been considering the C5 rotors and adapter brackets but just upgrading to the LS1 style seems like also a pretty good swap and much cheaper. Any thoughts over the improvement for the C5 rotor/bracket/C5 caliper over just upgrading to LSx style front brakes?
Rotor dimensions (dia) LS1 Camaro = 11.93" LT1 Camaro 10.94" C5 12.81"
So the 98+ F-Body rotor will give you better brake torque but reduced pedal sensitivity (depending on your tastes that could be good or bad but keep it in mind).
If you're on a budget, simply flushing your fluid to a new high quality DOT 3/4/5.1, bleeding the brakes and changing the stock rotors/pads will do wonders.
Seeing you "autocross" you might hit up Sam Strano and see what he recommends, he knows a LITTLE bit about that.
C5 brakes are 820$ for the below
- (1) Set - UMI Performance’s conversion brackets
- (1) Set - GM PBR Pressure cast front calipers
- (1) Set - Hawk HPS pads
- (2) Front Corvette C5 Raybestos rotors
So around 1000$ if you buy all new hardware for a SLIGHTLY better braking experience over LS1 brakes. I did the C5 conversion because I got a good deal on a setup, and they look goood. I am happy with it, but its not worth an extra 600$.
