Fueling & Injection - Who can flow match injectors
RsSean
02-12-2010, 11:26 AM
I bought a new set of 42lb injecotors, and would like to have them all flow match to one another. Any ideas on who can do this for me?
injectors: 42lb SVO ford injectors. Never ran in the car yet. Would need to have them back before March 10th
Thanks
Sean
Kevin@Vengeance
02-12-2010, 05:40 PM
Check these guys out.... they do all of our injector work... they are just North of Atlanta-
http://fuelinjectorconnection.com/shop/
rnl35thss
02-12-2010, 07:12 PM
+1^^^ Great guys and great work!!
ZL1Killa
02-12-2010, 10:30 PM
there is also RCENG over in california, and then in NC there is New Era perf. I think
Mike52
02-14-2010, 10:44 PM
Thanks
Sean
Sean, I think you misunderstand the principle of 'Flow matching injectors'. Flow matching requires a large quantity of the same injectors, say for example 100-200. The process is to flow all of the injectors, record the flow numbers, and then group them into sets of 8 based on their flow numbers being equal or very close to each other. This would be a Flow Matched set of injectors. It would be almost impossible to get the exact same flow numbers on the 8 injectors you already have unless they have already been matched. Flow matching isn't something that you adjust on an individual injector to make it match another injector. I hope this makes sense.
Mike
RsSean
02-15-2010, 07:18 AM
^ well i may be misunderstanding but, you can buy a set of 8 that have been flow matched to one another. Reason being is that cylinder 7 & 8 don't go lean. seeing how they are in the back
studderin
02-15-2010, 07:35 AM
http://www.youtube.com/watch?v=DUPqrgZdIU8
NewEra dose this. Did a set of used 36s I run in my car. I got a sheet with the flow data, and put the higher flowing 2 in 7/8 :D
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
