Sponsored by: DashLynx
2001 T/A headlights going all sorts of crazy ways after install.
Old 02-13-2010, 01:45 AM
Mr.Slow's Avatar
Default 2001 T/A headlights going all sorts of crazy ways after install.
Well, I decided to get numbers matching headlights for my '01 T/A that were rated a little brighter than the factory. Well, I had a few issues installing them(the screws were getting ground down on the heads) and after a difficult install, I test them at night.
The passenger low beam seems to shoot a bit low and it is like just a small ray of light shooting out 3 feet in front of me.
The drivers light shoots up in the air and looks like a spotlight aiming up.
Any idea what I could have done wrong? I know they are the right lights. Both lights say LF on the front. I thought it might mean left front, but every light at the store says that.
Old 02-13-2010, 02:20 AM
Copy & Paste Moderator
VIP1's Avatar
First, make sure they are properly seated in the brackets.
Second, use the adjuster screws to aim the headlights. There are two torx-head adjuster screws per bulb. One on top, the other to the side.
Also, "LF" doesn't mean "Left Front". LF / UF is the Category. I don't know what it means though. However, the H4703 low beam bulb will have "LF" on it and the H4701 high beam will have "UF" on it.
Old 02-13-2010, 03:05 AM
Mr.Slow's Avatar
Thanks a bunch! I have bought some new tools recently, including new torx heads(I'm hoping to tear at it tonight or tomorrow so I can start creeping around at night again. When all of the bolt on mustangs come out, bwahahahah.
Old 02-13-2010, 11:43 AM
VIP1's Avatar
BTW, you don't have to remove the plastic shrouds to adjust them either. The shrouds are notched so you adjust the headlights.
Old 02-13-2010, 02:50 PM
Mr.Slow's Avatar
Good info. My passenger side top torx screw is stripped though. I need another...
Old 02-13-2010, 09:23 PM
VIP1's Avatar
Try the Help! section at an auto parts store. I think I saw one there once.
Old 02-13-2010, 09:48 PM
383camaroz28's Avatar
mines doing the samethingg!
Old 02-14-2010, 03:51 AM
Blackbirdws6's Avatar
I find the adjusters strip out really easy for whatever reason but try using a 7mm socket on a 1/4" socket driver. Pretty sure that is the size if I remember. It will grab the outside area of the adjuster head rather than the torx portion in the center.
Old 02-14-2010, 04:33 AM
Mr.Slow's Avatar
Nice! Thanks
Quick Reply: 2001 T/A headlights going all sorts of crazy ways after install.
