85 mm maf ??
i was looking at the Fast toys lid's and the lid i want only works with a 85 mm maf.
I was told that i would able to use maf from gm suv
from 02 and up because gm decided to make them 85 mm maf or something like that.
The aftermarket MAF come with an adaptor. so would i be able to use one from those?
or is there a special adaptor for the ones from the gm suv?
Yeah, probably wise to spend your money elsewhere.
What lid was it btw?
EDIT: This one? If you're not pushing a ton of power, just get a regular lid. Pretty much all lids perform the same, I'd suggest SLP because of it's good fit
I wired the 85mm MAF into my car..
All you need to do is get the Connector, and look at it closely. The MAF has the IAT built into it, so you have to wire that in with the 3 MAF wires too..all the wiring was the same color for me so it worked great.
I'm planning on upgrading my stock cam to a 232/238
next year .
i'm trying to do some supporting mods before.
i'm geeting my trans build this year for sure new clucth and a cut out ,
next year .
