Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
hood?
Old 02-13-2010, 10:16 PM
ZonJuice's Avatar
Default hood?
im putting a carbed 1st gen sbc in a 93 camaro. i was wanting to use the vfn sunoco wide hood bolt on. but after looking at it, it has a support that runs underneath the cowl. its right where the carb is goin to be. i was just wondering what people are doing about this or what hood people are using. i really need a tilt hood not a pin on. im using a spectre carb hat.
Old 02-14-2010, 06:53 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, on mine i just cut out what i had to to let the intake setup clear:
Old 02-14-2010, 01:12 PM
BassProCamaro97's Avatar
I did the same thing as Zone.
~Jim~
Old 02-14-2010, 09:15 PM
Spankie's Avatar
not sure about the carb hat but with a small air cleaner stock hood will work
Old 02-15-2010, 07:50 PM
ZonJuice's Avatar
im probably going to have a nitrous plate so stock hood wont clear it.
zone- have you had any problems with the hood flexing of being flimsy? i think with the carb hat im goin to have cut out the whole crose peice
Old 02-23-2010, 07:31 AM
It makes the hood a hair "looser" or flimsy.
I cut the entire cross piece out and I'm not really having any trouble.
The only thing I can see being an issue so far is the large opening being quite accessible to water. Especially when you are washing the car (runoff from the windshield)
Not sure what sort of intake you are running but I have a really high setup and I got it to fit underneath a 3 inch cowl. Check my sig for pics.
Good luck,
~Jim~
Quick Reply: hood?
