car wont lock by key fob, but will arm alarm
Old 02-15-2010, 01:00 PM
SheffyZ28's Avatar
Default car wont lock by key fob, but will arm alarm
hit the lock button once and it honks once, alarm is armed but doors are unlocked, any ideas? oh and im thinking of moving to a better security system, with remote start, any recommendations? not real good with security stuff. thanks
Old 02-15-2010, 01:49 PM
SparkyJJO's Avatar
Try locking the doors with the power lock button instead of the fob. Does it do the same thing? Arm the alarm but not lock the doors?
If so, you've got the same issue I had. Relays in the BCM wore out. "Easy" fix if you know what you're doing with a soldering iron and can source new relays (that was the hard part for me).
Old 02-18-2010, 04:54 AM
SSdimension's Avatar
No bullshit my car did that and I had one of the parking lights went out. I replaced it and it works fine. Another thing I might ad if you have an aftermarket stereo that might be the problem. But when I changed mine it said security on the instrumen cluster and found out it was some wire that was hooked of wrong. Hope my advice helps
Quick Reply: car wont lock by key fob, but will arm alarm
