WTF!? It cost 6 Trillion Dollars to machine a LS block!!!???
I just got some quotes to machine my LQ4 and I about **** myself! These prices are insane if they are on par with everyone else...
I'd be willing to take my **** to another city if I can find better $$$. These prices are insanity! Fuuuuuuuck!
Here is the list:
Disassemble - $100
Hot tank: $96
Magflux: $72
Pin bearings: By Hour
Line hone: $230
Line bore: $200+
Cylinder bore w/ tq plate: $252
Fly cut: $150
Deck: $191
Assemble bottom: LB- $695 SB- $458
Balance rotating: $394
Clearance: $250
DM
Here is the list:
Disassemble - $100
Hot tank: $96
Magflux: $72
Line hone: $230
Line bore: $200+
Fly cut: $150
Deck: $191
Clearance: $250
DM
Hell yeah Bro... PM sent!
I am from Miami so I'll make it a weekend, lol, drop the block off then go check my peeps out... That is if the $$$ are better.
I had a raw cast Bow-tie block (SBC) machined for a 383 stroker back in the day and it did not cost as much. Hell I had to had the block clearanced for the crank and still it ws cheaper.
DM
DM
I don't have the break down in front of me but between machine work balancing bearings pin fitting, blah,blah,blah ended up at at like $1800 and I feel like its some of the best money I've spent on my car
Do you not have tools? Is your engine that screwed up? My friends motor, so far thrust bearing went out. Looking at parts and the machine shop we are at $1k or so to get him back up and running. That is with us completely disassembling, and for reassembly the machine shop is only installing the crank/rods/pistons as I've never done that and I don't want a motor that isn't my own to be my first. So we are reinstalling the top end and cam. Its not hard. Like I said though, not a lot of damage on our end, just hot tanking the motor, a hone, new bearings and freeze plugs.
Your motor is so messed up you need a ton of work or what is the story? Why not find a decent shortblock that doesn't need all that machining and go from there? Find a shortblock that has the displacement you already want? I don't know, I bought my whole engine for $1900 shipped, oil pan to intake manifold with longtubes(granted a LT1, but it makes 353rwhp/351tq), sometimes building isn't worth the cost if you can find what you want already built and just drop that sucker in!
I can't believe that the prices are not better, especially in this economy. It's not like it is such a diverse type of business to where they can make up lost revenue by other means; I'm sure these shop are not doing too good since engine building is not a high priority let alone people having the extra money to do anything. You would think price would be lower to pull in business. I know that in the construction field here in Jax, contractors are cutting each others throats just to make $0.50. A good time for the consumer (as long as you have the $$) bad time for business. I am not a cheap individual, hell... I had $25K invested in my 3000GT VR4, had the BEST of everything, however, times have changes and my school budget now dictates what I can and can not afford, so yeah, it is a buyers market and anyone would be a fool not to shop around, and like wise, a any shop would be a fool not to realize that.
Hell, I felt the sting of this economy as the seller, I just sold my Brand New $700 HKS EVC 5 boost controller for $320, so I'm not just talking out of my *** here, I feel it too. Other losses I've had recently - Carbon Fiber drive shaft (less 500 miles) Paid $1300 Sold $500 / Turbos (less 500 miles) Paid $2300 Sold $900. That is just the tip of it all, so yeah times suck!
Anyways, sorry to rant, lol, please keep posting referrals for me to call, thanks guys!
DM
rob lizzy at central fl machine. kinda far from you but he is the best around, tanked, turned the crank, bored the block, freeze plugs, cambearings, and Assembly on my 455 pontiac for less than 900
Robert up here at CFM&S is good as mentioned and you also have CRE here in Orlando.
Down that way you may want to look into the machine shop at Mustang Specialties on Dixie in Ft Lauderdale. Ronnie runs that shop and is doing more and more LS engines. Would not hurt to check it out and tell him I sent you that way.
Most importantly, do not just shop by price. Get as many referals as possible on the less expensive guys because it could cost you more in the long run. This is one area to not be cheap in at all. Do not get taken adantage of by any means, but be careful.
Mike Norris
Mike Norris
