Help- where does this go?
Old 02-16-2010, 01:51 PM
danbrazda's Avatar
Default Help- where does this go?
Rear of driver's side not far from #7. One end is hooked up but where does the other end go?
Old 02-16-2010, 01:59 PM
Customizing Director
MadIceV8's Avatar
That is used for tha AIR pump system. One end will go to to vacuum on the back of the intake manifold. I believe there should be another end that goes to the AIR pump itself.
Good spot to hook up a boost gauge if you removed the AIR setup.
Old 02-16-2010, 02:09 PM
danbrazda's Avatar
Thanks MadIce. The AIR system was removed. Is it OK to leave the wire unhooked as in the picture or will that constitute a vacuum leak? Plug it or just leave it?
Old 02-16-2010, 02:16 PM
Kleeborp the Moderator™
MeentSS02's Avatar
You can just plug it by sticking it on one of the exposed studs on the coil bracket...I just took the whole thing off though.
Old 02-16-2010, 02:32 PM
danbrazda's Avatar
Gotcha. So the other end that is plugged in currently is plugged into...what?
Old 02-16-2010, 02:43 PM
MeentSS02's Avatar
I think that is the purge solenoid for the AIR system...it's been so long, I don't really remember.
Old 02-16-2010, 03:02 PM
danbrazda's Avatar
Yet another piece that can disappear. Just shaved off another 3 ounces. Woo hoo! That has to be worth a tenth in the quarter.
