impala ss 2006 halo CCFL turning off
Hi guys,
so I installed a lowering kit from SSC and black CCFL projector headlights...for some reason the Halos on the right headlight turn off after a while of being on...i have to turn them off and then back on for them to light up...any ideas?
It could be the little transformer on the bottom of the light, I accidentally got the transformer wet while cleaning the engine bay one day and it went out on me. But easy fix, ordered a new transformer from sabersports on ebay, very cheap $15 for 2 of them and that includes shipping, just have to email sabersports and tell them what you need and they will hook you up. The transformers do have a pos and neg wire on each, so when hooking them back to your light you will have to switch them around until your halos are bright, if you have them wrong they will be very dim. But really no big deal. Hope this helps, hope this is whats wrong.
Thanks a lot for the info guys...i took it to the chevy dealer the other day and the tech told me it was the ballast...can i order these anywhere? its too much of a hassle to send these babes back
I've sent two sets of those lights back. They do look sweet for about 2 months but after that they are a bitch. They fog up, flicker, don't fire properly, and that ballast either detaches and breaks or gets wet and dies.
So, I got new ballast from Automotive lighting concepts they worked like a wonder for 2 weeks and now the same CCFL I had a problem with is dead I checked the ballast and its blown....can't think of any solution....any help would be appreciated
Hey guys I heard that if you have these projectors that you can not install HIDs in them is it true? I have the HIDs but i want the halos but if they dont work then ill put them in my stockers
Here's a link to (a link to) replacement inverters...
https://ls1tech.com/forums/ls4-front...inverters.html
I'll be sure to update that thread if I have issues with these inverters.
I have HiDs and they're perfectly fine. However, you need h3 or h3c HIDs for the projectors and H11 in the stickers. They're not compatible.
BuffaloSS: I changed the CCFL inverters twice and the same problem keeps happening on the same side as well..a lot of people swear by switching from CCFL to LEDs which is what I am doing, they have to take the headlight apart by heating it up and stuff(you know for the glue) so it'll take some time...labours is a B**** over here.
I'll let you know how it goes once it's done though
Hell...send'em to me and I'll do them for you for $300. ;D
