Pontiac GTO 2004-2006 - bluestreak
deputywatson
02-16-2010, 08:03 PM
hey guys new to the site and have a question just bought a 06 gto and have installed new headlights with HIDs and they flicker and pass. side turns off randomly i have put in code eliminators and wonder if i should still disable the DRLs or will the code el.fix the problem THANKS
badpontiacs
02-16-2010, 08:14 PM
Codes? I have HID in my fog and low beams, I have an 04 so maybe thats the difference.
twank06
02-17-2010, 10:33 AM
disable your drl's. also check you bulb might be going bad or ballast
05TurboCGM
02-17-2010, 08:44 PM
No idea what code eliminators are, but you need to pul your DRL relay. The wattage is not enough and it can ruin your bulb/ballast. A flicker is usually an indication of a ballast problem so see if you can swap them if the DRL doesn't do the trick.
hivoltagedriver
02-17-2010, 10:09 PM
What wattage are the HID's? You might need to boost the voltage to the ballasts via a relay. There are wiring harnessesavailable that are plug-n-play.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
