header install... ? about AIR and EGR
Hey guys I'm about to do my pacesetter longtube header install and I was wondering if there was anything else I need to get so taht when I decide to start on the install I don't need to order more things to finish her up. I have an 01 ws6 so I don't have the EGR I believe but about the whole AIR thing should I just keep it? I have the spots for them on the headers but I was jsut wondering if it was a big pita or not. And also another question... i think my headers have the EGR fitting on them too. Do I need to order a block off plate if thats the case? Or can I just fab one up real quick that'll just block it off?
Most if not all AIR and EGR questions answered here: https://ls1tech.com/forums/generatio...mount-faq.html
Compared to the header install, removing the AIR will be a walk in the park, the provisions on the headers will need block-offs if you delete the AIR system.
A homemade block off plate or a purchased block off plate will work the same on the EGR provisions. Use some RTV to get a good air tight seal when you put it on.
