Clearing Codes Permanent?
I have two codes 1416 and 0440. I have fixed both issues to the best of my knowledge however, the SES light is still on. My question is, if I "clear" theses codes with my Diablo predator, will they permanently disappear even if issues still exists? Or will the same codes simply re appear a short time after I "clear" them. Thank you.
no they will not be permantely deleted unless the problem has been fixed. you will have to delete the codes and then run your vehicle through a couple drive cycles(open and closed loop) if the codes doesnt reflash then you are good to go.
^^^^ yes. for those who dont have access to tuning software they can leave the battery unplugged for a little bit and hook it back up.... that will clear codes. If the light comes back on...... your going to have to find the source of the problem
Pepboys
Advanced.... most places will tell you for free
Pepboys
Pepboys
Pepboys
