Vic Jr. Throttle Bodies
Old 02-17-2010, 02:02 PM
Z28Caves60's Avatar
Default Vic Jr. Throttle Bodies
I've seen a lot of people run accufab throttle bodies but i was wonder why accufab why not edlerbrock or some of the other companies out there?
Old 02-17-2010, 03:37 PM
LSWNDR's Avatar
You know i'm really not sure i think it's prefference really as long as you have the higher flowing one to keep up with everything else in the same range more than likely you won't have any issue's. Research the threads on the Vic jr intake an 4-Brrl TB's you'll be pretty impressed... I'm going with this set-up because i want the maximum power potential of my build an i want to make power from 3500 to 7500 so somebody recomended this way to go an they told me either way you go as long as it's the max flowing one which ever company it is i shouldn't have any issues with it.
Old 02-17-2010, 09:06 PM
1CAMWNDR's Avatar
I chose the Accufab because it is the shortest high quality 4BBL. And it was included in the parts I bought.
Old 02-18-2010, 02:48 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ They are the shortest and when you are trying to cram them under a bird hood it is tough. I have an accell that is slightly thicker, but flows more.
