New LS1 Owners - Newbie Tech - Best way to clean MAF?
View Full Version : Best way to clean MAF?
StoreKeeper99Z28
12-27-2003, 05:11 AM
Since the car is 5 years old and have been using a K/N filter I figured it might be time.
How do you tell if it is dirty?
How do I clean it?
It's a Granntelli (sp)
Thanks in advance
Rx Bruce/StoreKeeper99Z28
Nine Ball
12-27-2003, 06:38 AM
Go to your nearest Radio Shack or computer parts place, and pick up an aerosol can of electronics parts cleaner. It works well and evaporates very quickly. That is what most of us use. Some cleaners will leave a film on whatever they clean, and that would screw up your MAF readings. Only use electronics cleaner.
y2k_ta
12-27-2003, 07:49 AM
Is it still necessary (or just good practice) to clean a MAF even if it has be de-screened?
onebadz
12-27-2003, 11:10 AM
I think they are talking about oil from the filter getting on the sensing elements of the MAF. If you have a paper filter I woulnd't think you would have to worry about it, but if you have any oil base filter you will probally need to clean the MAF after a while regardless if it's descreened or not. Good Luck
Wes
y2k_ta
12-27-2003, 03:40 PM
I'll keep that in mind....I've put about 95,000 miles on the car since installing the K&N, so I guess I'd better clean it sometime soon....
StoreKeeper99Z28
12-27-2003, 04:57 PM
So what I'm hereing is to remove the MAF from the car and spray it down with the Electronics Cleaner and re-install?
If not how do I go about the whole procedure?
Thanks for any and all input!
canadian z28
12-27-2003, 05:04 PM
once you get the MAF out, take some time and clean your throttle plate and bore. Bet ya it's black and gungie. I use air intake cleaner and a toothbrush. Also, pull the IAC motor out and give that a scrub. Get a rag and put your finger in the IAC bore and twist your finger in there and alot of black crap will come out of there too.
StoreKeeper99Z28
12-27-2003, 05:10 PM
I just had a new ported Throttle Body installed about 1 month ago.
Rx Bruce
samz28
12-27-2003, 05:17 PM
best way to clean maf imo is to take it out, place it in a big freezer bag with pure rubbing alcohol, shake n bake and let it sit overnight.
We use this method for VW maf's which have a very high tendency to fail due to K&N Juice (oils). It cures almost all of the cases of low maf signal. They are very fragile. I'd assume a similar action would work on all other cars as well.
Don't over oil your K&N it will make the maf's life miserable.
Ferocity02
12-28-2003, 12:34 AM
I just used some Q-tips and alcohol to clean mine. Went really fast without any trouble. Be very careful though, the resisitors are extremely easy to bend and break off.
smokin' joe 00 ss
12-28-2003, 06:29 AM
Like Nine Ball say's get some contact cleaner at electrical part's store, it's quick and easy and it's what GM uses.
