flywheel difference between 4.8/5.3/5.7
Old 02-18-2010, 03:35 AM
jeejee's Avatar
Default flywheel difference between 4.8/5.3/5.7
is there much (if any) difference betwene the smaller engine flywheels and the 5.7 ls1 ?
in particular this diameter :
the diameter is about 6.45 inch (16.3cm's)
i'm planning on using this clutch and plate :
so you see , i need a bit of extra meat for the plate.
i don't feel confortable welding material on a cast flywheel do get this done, so need a different flywheel with a smaller clutchplate bas
Old 02-19-2010, 03:23 PM
jeejee's Avatar
anybody ?
Quick Reply: flywheel difference between 4.8/5.3/5.7
