soft clutch
Old 02-18-2010, 03:43 PM
SmkSho's Avatar
Default soft clutch
When i go through the gears a high rpm my clutch wants to stick about half way to floor and it then pops back into place . I have a 2001 SS m6. What is causing this and what can i do to fix it.
Old 02-18-2010, 04:03 PM
TooLateVTEC's Avatar
From what ive read, you need to check the fluid to see if its dark. If it is it needs to be changed before the slave cylinder takes a ****.
Old 02-18-2010, 07:41 PM
Z28_LT1's Avatar
look up "drill mod"
