*STOCK* LS1 Dyno Numbers POST! (Do A Search)
Old 02-19-2010, 06:19 PM
Blazin95's Avatar
Exclamation *STOCK* LS1 Dyno Numbers POST! (Do A Search)
i have a 02 SS Camaro non SLP option car its a 6 speed with 120,000 miles on the stock motor
its has a K&N Air filter Whisper lid and MSD coil packs (only because stock ones failed which i know don't give any power)
just finished getting it tuned last night and it put down 363 Hp and 365 TQ
will have a print out asap to prove this but i was curious what other stock
LS1's are putting down and if yall think that mine is a factory freak or something
Blazin95 is offline
Old 02-19-2010, 06:43 PM
LS1W66's Avatar
Pretty happy dyno if you ask me, and this is why IMO Dyno numbers don't mean much in the real world. Take it to the track and see what the car runs as far as trap speed because that is a better indicator of real horsepower.
LS1W66 is offline
Old 02-19-2010, 06:51 PM
disc0monkey's Avatar
this dyno **** is really getting out of control. i cant look at them anymore. this guy puts out the same as some bolt on mild cam only cars.
dynos are only good for before and after comparisons between mods.
disc0monkey is offline
Old 02-19-2010, 07:08 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,459 Likes on 1,052 Posts
Either there is something wrong with that dyno, or the dyno operator, or your car is not nearly as stock as you are claiming (not saying you're lying, if you bought it used you might have mods you don't know about).
Fact is, an '02 LS1 that's totally stock besides an air lid and tune does not make 363rwhp.
RPM WS6 is offline
Old 02-19-2010, 08:38 PM
MikeWS6's Avatar
Stock ls1 cars put down right around 300rwh, which is about 350 flywheel. Anything over 315hp stock is a happy dyno if you ask me. 365 is usually what full bolt on/ mild cammed ls1s make.
MikeWS6 is offline
Old 02-19-2010, 08:48 PM
rtr2001ss's Avatar
My 2000 Z28 A4 with stock airbox/lid, Free Ram Air mod and a 3.42 Rear end made 317/330. This is the same dyno that I dyno'd my SS on when it was stock with a Lid only and that one made 309, forget the torque. The highest I've personally seen a stock F-Body go was 320-325, the ones I usually see with higher #'s tend to be the 1SC option cars. Go figure the cheapest and bare bones F-Bodys you could get were the ones that typically made the most stock HP.
Either way, dyno is more of a tuning tool as well as seeing what your mods have gotten you. The Traps through the 1/4 mile tell the real story.
rtr2001ss is offline
Old 02-19-2010, 08:49 PM
Super Speed's Avatar
This!
Super Speed is offline
Old 02-19-2010, 09:39 PM
registered user
ScreaminRedZ's Avatar
Agreed with the above responses.
ScreaminRedZ is offline
Old 02-20-2010, 06:28 PM
BriancWS6's Avatar
You didn't mention if these numbers are SAE or STD corrected. Either way, those mods wouldn't translate to those numbers on an accurate reading dyno. If the numbers are indeed legit, the car has had some modding done that your not aware of by a previous owner.
BriancWS6 is offline
Old 02-21-2010, 02:10 AM
Blazin95's Avatar
all i know is im the second owner of the car i put it on a mustang dyno which reads lower than any other dyno now maybe yall are right and there is stuff done to the car i don't know about and maybe his dyno is reading wrong all i know is it dynoed 363 and 365 twice in a row but im going to another dyno just to make sure of whats its really putting down.
Blazin95 is offline
Old 02-21-2010, 02:50 AM
Blazin95's Avatar
oh and if you mean the weather control factor (WCF) which is what is says on his dyno put the numbers at 358 tq and 356 hp the 363 and 365 where max tq and max hp
Blazin95 is offline
Old 02-21-2010, 02:56 AM
travismcgillsdaddy's Avatar
if its stock there is no way your making that much power on a mustang dyno
travismcgillsdaddy is offline
Old 02-21-2010, 05:52 AM
registered user
Haha, take it to the track. Maybe you have the only stock fbody that traps 113mph
Old 02-21-2010, 10:51 AM
jonlisa973's Avatar
Looks like a stock LS6 motor.
jonlisa973 is offline
Old 02-21-2010, 11:08 AM
cali_bear2003's Avatar
From what I have read, I have to agree with the above statement. The corvette c5 z06 are supposeably equipped with better flowing exhaust manifolds, cat and muffler systems then our f-bodies. From what I have seen online, most dyno in the low to mid 350 range to the ground. Some people are even boasting mid 360's to low 370 range to the ground. Even with the LS6, those higher number are questionable with a stock powered car. Just my thoughts, but those are nice numbers.
cali_bear2003 is offline
Old 02-21-2010, 12:42 PM
Blazin95's Avatar
to my knowlege the car is stock yall have to remember i bought this car used i have no idea whats done to it.
everything i have done to this car since i have owned it is listed below
1. 255 walbro because stock fuel pump was cutting out and breaking up(zero power)
2. short throw which adds zero power
3. K&N air filter(maybe 10HP)
4. Whisper lid(maybe 5HP)
5. Replaced facotry MAF with updated model because car would break up on 4th gear pull
6. MSD coil packs which fixed the break up on 4th gear pull(zero power)
7. MSD 8.5mm plug wires
8. HP tuner
9. Flowmaster catback which was on the car whenever i bought it from a dealership
now the first time the car went on the dyno it made 344 hp and 348 TQ no that is with it breaking up on the 4th gear pull
Fixed the breaking up problem redynod and it made 363 hp and 365 TQ (these numbers were max hp and tq
now im not trying to say my car is ungodly fast or anything im just want to know how my car is making these numbers on a mustang dyno i don't believe they are acurate IMO just curious to see what yall think
but the car will be going to another dyno to make sure and if it still shows those numbers then i will take it either to Tick performance or R.P.M which are very reputiable shops and see what it does there
Blazin95 is offline
Old 02-21-2010, 01:05 PM
RPM WS6's Avatar
In that case, I am even MORE sure that your car is not as stock as you think it is. No way in hell does an LS1 make 363rwhp on a mustang dyno with an air lid, catback + tune.
Not even close. K&N is good for somewhere between 0 and 2hp.
You've under estimated here. An air lid is worth about 10rwhp on a stock car, give or take a couple hp.
RPM WS6 is offline
Old 02-21-2010, 01:22 PM
Blazin95's Avatar
well if it has stuff done to it i would love to know what it is yah know
Blazin95 is offline
Old 02-21-2010, 03:06 PM
blackcamarob4c's Avatar
My stock 02 Ls1 did 326/357....Lid/Filter
http://www.youtube.com/watch?v=d8OG3QdQZXY
blackcamarob4c is offline
Old 02-21-2010, 03:32 PM
Pate_2008's Avatar
My stock 150,000 mile motor, and stock trans with stock conveter with only headers, lid, exhaust and free mods, and tune. went 12.78 in the quarter and 11.66 at 117 with a 150 shot ! ~
Pate_2008 is offline
Quick Reply: *STOCK* LS1 Dyno Numbers POST! (Do A Search)
