Big oil leak after LS6 intake swap. It's now fixed!!!
Old 02-19-2010, 09:49 PM
1gt2nv's Avatar
Default Big oil leak after LS6 intake swap. It's now fixed!!!
I put on a LS6 intake last weekend. Yup, I broke the oil pressure sending unit. Got a new one. I started my car today and it was leaking oil under the car. Could it be I didn't tighten the opsu enough? Do you have to tape the threads of the new opsu? I don't think it could be anything else that would cause the leak. Any help would be great. Thanks.
Old 02-20-2010, 12:20 AM
MjMaro's Avatar
Don't need to tape the threads on the opsu, try to locate where the oil is coming from and that will help us figure out what's going on with it.
Old 02-20-2010, 06:27 AM
MonmouthCtyLS7's Avatar
Busted one also while i was installing my typhoon, only thing I could think of is check and make sure you didnt bust it again, they snap pretty easily. Dont really need to tap anything.
Old 02-20-2010, 09:29 AM
1gt2nv's Avatar
I'm going to take the intake off today and see if the opsu broke. The gauge in the car works and reads as it should. Maybe I just didn't tighten it enough? I'll get back on here when I look into it some more.
Old 02-20-2010, 12:24 PM
1gt2nv's Avatar
Got it fixed! I took the intake off. I must have not tightened the opsu when I put the intake in last weekend. It was only hand tight. Opps. I put some teflon on the threads just to be sure. I tightened it down real tight. I even have the socket for the opsu. Must have forgot to use that last time. Lesson learned. Started the car, no more leak! I'm getting good at swapping intakes now. lol
Old 02-20-2010, 01:36 PM
Dewman's Avatar
torque wrench are your friend.
Old 02-21-2010, 09:11 AM
1gt2nv's Avatar
For a opsu? I only had it hand tight. Then I went back in and tightened it with the opsu socket I have. Got it as tight as I could.
Old 02-21-2010, 11:06 AM
jonlisa973's Avatar
Glad you fixed it! Sometimes even the simple things get overlooked!
Old 02-21-2010, 12:46 PM
wytry's Avatar
I forgot to torque down the coolant crossover lines, which resulted in a lot of wasted Dex-Cool and me taking the intake off. Again. Lol. Glad you got it fixed!
Old 02-21-2010, 04:21 PM
1gt2nv's Avatar
[QUOTE=jonlisa973;12925452]Glad you fixed it!
Thanks guys. I'm glad I got it fixed also! I hate it when something is wrong with my car. I can't sleep at night cuz I think about what is wrong and how to fix it. lol
