back brakes scraping
alright here's the history. I'm not sure of the milage on the pads or rotors but they look almost new and are definately no where near being having to be replaced. with my stock rear end they never made a noise. not one sound. i put in my moser rear and have had major problems with the scraping on the outsides of both rotors. the inside looks totally normal. a deep grove is getin work into both at the same place which is about in the middle of the pad. its tearin my rotors to ****. i turned them in the shop yesterday as well as greased the slides and it's STILL draggin like hell. any ideas? i can't figure out what's goin on
actually i think that's exactly what it is man. cause there are some spots on the caliper that i suspected for dragging. you just gave me an idea. thanks a lot man. i really appreciate it!!!
well i took a closer look and realized it looked as if the out side caliper bracket was scraping on both sides. i took the the slides out and grinded the bracket on the inside(of the outter side) to give it a little clearance. made it better but something still isn't right. the sound is like wear indicaors on a warped rotor. metal on metal basically. anybody else have any ideas or ever had this happen?
There could be too many different thing going on there. Remove your rear wheels/tires, calipers, and rotors, take some pics of the axles going into the tubes. Install the rotor and calipers then torque on your lug nuts up against the rotor, make sure the rotor is seating properly. Take some pics of the inner clearance in between the rotor and the caliper (I think this where you are saying the rubbing is going on).
yeah i put the lug nuts on the rotor and put it in gear. thats why i thought it was the inner caliper bracket. ill take some pics when i get a chance. thanks for the help so far guys
