I have the moser 12 bolt with out c-clips. I didn't get any assembly instructions and I am in dire need of info on how the bearings and seals are pressed on to the axles. Pictures would be helpful also.
Basically you need to have them pressed on, and the backing plates need to be in between. Sort of a PITA if your doing a swap and you need to have the rear still in the car.
