monster tourque install specs.asap
ok i just pulled out my monster 3.5 and i cant find the tourque specs anywhere so if anyone knows flywheel to crank,and pp to flywheel i can put it back together thanks.
I have the level 3 w/ light weight flywheel...
For the FW you torque them down in three phases 15-37-74ft. lb in a 1-4-6-2-3-5 sequence around the FW
For the PP is 20-40-52 ft. lbs in a 1-4-6-2-3-5 sequence
Hope that helps
Hope that helps
