PCV system ?'s
Old 02-21-2010, 04:34 PM
C LOWERY's Avatar
Default PCV system ?'s
I pulled the intake today and while I was in there I found all the hard plastic hoses on the PCV system broken. 1 three inch piece is missing. The Y near the back of the intake is also broken. This thing has been broken for quite a while by the looks of it. (I just got the car in Aug.)
My question is: If I get the REVXTREME catch can does it come with everything I need to replace the entire PCV system or will I need to buy a good PCV system and then modify it to work with the catch can?
I am not having good luck finding any real good info on these or where the best place to get one is.
Any other suggestions??
Old 02-21-2010, 04:46 PM
nauticalstar2012's Avatar
I would imagine those two leaks caused aweful vaccum leaks. Fix those and add the rev extreme can and I bet it runs alot better
Old 02-21-2010, 05:14 PM
01'SSLSX's Avatar
no the catch can will not come with enough hose for the Entire PCV system.
but 3/8 fuel hose is same thing, u can get it a parts store Cheap.
Old 02-21-2010, 06:30 PM
C LOWERY's Avatar
I went back out and looked it over and I see a way to fix it. I should have looked a little closer before posting.
Where should I look for the catch can?
Website?
Old 02-21-2010, 06:32 PM
C LOWERY's Avatar
By the time I get done with this car I hope to be able to answer questions for people instead of only asking all the time.
I am still just a NEWBIE to these LS cars; but I'm learning.
Thanks for any help fellas.
Old 02-21-2010, 09:02 PM
01'SSLSX's Avatar
i got my catch can from elite engineering.
Old 02-21-2010, 09:27 PM
Traitor LS1's Avatar
I don't even know why people bother running a PCV system... Dual breathers is what I run and I have no oil in my intake period. I used to run a catch can but still some oil mist made it's way into my intake and got it somewhat dirty, but nothing like before. So I just say scrap your PCV system all together and save the cost on a catch can setup and clean up your engine bay without making it more cluttered.
Old 02-22-2010, 12:03 AM
Ryans99ls1's Avatar
can you really just eliminate the PCV system by putting a breather on each valve cover?
Old 02-22-2010, 11:12 AM
wytry's Avatar
Some people are fond of the breathers, some like to retain SOME sort of PCV system...depends on how you feel about the situation I guess. I'm retaining the PCV system, but switching to the LS6 style. There is much less hose clutter and it is "supposed" to eliminate the oil consumption. We shall see...
Old 02-22-2010, 12:09 PM
Yep well pretty much that and cap off a couple vacuum lines just search on here and you will find info on it. It's VERY easy to do. People complain about it making a burning oily smell I can only smell it when I pop the hood and sniff right by the breathers haha it isn't noticable at all IMO.
Old 02-22-2010, 12:12 PM
Yeah the LS6 PCV is better than LS1 that's for sure but I know a few people who run catch cans with an LS6 PCV and still get a little bit of oil in there so they still suck oil but nowhere NEAR what an LS1 PCV does. I would just delete it you wouldn't have to spend the $150 or so on the LS6 PCV system or notch your block to fit it and install it etc. etc. When you can get better results spending 5 minutes and deleting it. and Save $100+
nemss1's Avatar
capped off mine and installed breathers as well. still need to get a breather oil cap for mine
Old 03-27-2010, 11:01 PM
KnightmareCS's Avatar
hey guys, any pics of your breather setups?
just learned about the whole PCV system, LS1-to-LS6 valley cover swap and catch cans in the last 2 hours. there was oil loss when we changed the oil last, so i'm looking for anything that'll help it. i don't know what's on the car now as it was bought used. i'll take a look at it in the morning.
