Car missing/sputtering question?
Well first off awhile back my car got some water in it and sucked into the intake and somewhat in the car due to some flooding and it hasn't seemed to run perfectly since then.
I know it isn't something big because the motor sounds healthy with no knocks, pings, or any strange sounds at idle and WOT. But what it does is it seems to drive fine sometimes and then all of a sudden the engine will change tone and seem like it goes about 50% power then it will kinda miss a little and sometimes pop. Then you give it some gas and it seems like it returns is seems fine. I recently did most of the minor things that I figured it could be. I changed the spark plugs, wires, fuel filter, and cleaned the MAF.
The car actually will drive fine for awhile and then it will pull a code up after some driving for an o2 code, bank 1 sensor 1. Could this be the only thing it could be? I tried cleaning the o2 sensors but maybe I just need new ones because maybe they got wet when it flooded. Could the wires on the MAF went bad? I know water did get into the intake but none got sucked down because I turned the car off and removed the intake that night and made sure everything was dry. Tom. I guess I will removed my MAF from my friends car and see if that's it? Any suggestions?
Well a minute ago I went out and unplugged the MAF to see if it could be there? It ran like complete **** and couldn't catch and idle and kept dying and it was hestitating really bad while driving. I'm not sure if it matters that I have an SLP 85MM but the car is a head/cam car tuned?
I'm having the same problem my car is sputtering, and driving like crap, and engine light blinks, but I have no cats, and I took it to the dealership and the scanner didn't read anything at the time, i'm thinking its the 02 sensors but i'm not sure, i'ma replace them and see what happens cuz i've spent too much money on this problem already. o and i already re-routed the crank sensor so it would get fried.
