what times should i get??
i was just wondering what kind of times i should see when i get done with my car, i was thinking low 11's... and what else could i do to get me in the high 10's?? this is what i have that i just put in:
forget 347
patiot stage 2 5.3's
pt4400
tr230
stock 3.23's
some bolt ons and just got a rear pass side airbag cause i heard those help..thats just about it any other tips??
forget 347
pt4400
tr230
stock 3.23's
Motorboater
whats your suspension setup like.
might not be able to get the sixty foot needed for those times if all your suspension is still stock..that 10 bolt might say by by too, always hard to say with a light A4 car though.
sound like the HP and converter are there, just curious about what you got for putting it to the pavement.
just the air bag for now, but i am getting a adj. t arm pretty soon and most likely a rear end back plate or girdle
i also have et streets but im gonna see how those hook and if they dont, ill get some drag slicks ... what 60' time should i see with a high 10 sec pass?? thanks...dwayne
hey i want to also.. see how the t arm and all the other mods you got do, then slap those heads on after the ewp... but we will, and my modding is over!!
j/k!!!!!
j/k!!!!!
forget 347
pt4400
tr230
stock 3.23's
forget 347
pt4400
tr230
stock 3.23's
A shock/spring setup might be something to consider. (front sway bar removed). Is the car tuned properly? I wouldnt worry about the rear until it breaks, i know someone that is still running a 10-bolt w/3.23 gears on their H/C car. Do you have any weight pulled from the car? Why are you selling the lightweight battery?
