Gen 5 Camaro Suspension Tech - Eibach Camaro SS test: better performance and 13% better MPG [Video]
PostRelease
02-22-2010, 11:55 AM
http://postrelease.com/image/view/3729.jpg
Eibach 2010 Camaro Suspension Performance Test
Using a 2010 Camaro SS, a series of performance tests were conducted by TestPilots Independent Testing Services and drifting champion Sam Hubinette.
http://www.postrelease.com/content/advertisers/images/129_0345f0caaf1e4be58f07388b2c875988.jpg (http://postrelease.com/ServePRCLick.aspx?id=61605)
Click here to wach the Eibach Camaro suspension test (http://postrelease.com/ServePRCLick.aspx?id=61606)
Baseline tests with the stock Camaro SS were conducted using state-of-the-art testing equipment. Then, off-the-shelf Eibach Pro-Kit progressive lowering springs and Eibach Anti-Roll-Kit were installed - no other changes were made to the vehicle.
http://postrelease.com/content/advertisers/images/129_f8afdc1b3e51486891674d15ae180ff8.jpg (http://postrelease.com/ServePRCLick.aspx?id=61607)
Even though the air and track temperatures were much higher, the Eibach-equipped Camaro outperformed its stock counterpart in nearly every test.
While the SS suffered from persistent understeer in stock configuration, the Eibach Pro-Kit springs and Anti-Roll-Kit turned it into a much sharper, more responsive machine.
To learn more about the performance testing, check out the video at www.eibach.com (http://postrelease.com/ServePRCLick.aspx?id=61608).
This PostRelease (http://postrelease.com/)® is part of an advertiser-supported program that sponsors LS1 Tech. This program delivers relevant news and announcements as posts within the LS1 Tech forum. If you have any questions or if you're interested in using PostRelease on this forum, click here (http://postrelease.com/contact-us) to contact PostRelease.
