Driver Side Window Problem
Old 02-22-2010, 03:45 PM
99bullitsilverTA's Avatar
Default Driver Side Window Problem
Look guys I have a problem, someone tried to break into my car, and in the process broke my driver side window. The motor works fine and the regulator works fine as well. But where the guide roller connects to the window itself at the bottom of the window the cast bracket attached to the window broke. The roller just broke off the window so there is nothing to guide the window up. Is there a way to fix this?? Is there a replacement part for that or do i have to pay some body shop to fix it??
Old 02-22-2010, 07:28 PM
nemss1's Avatar
all u need is the plastic roller then. they just pop in. u may try a dealer unless u can find one in a salvage yard
Old 02-23-2010, 08:11 AM
the roller is fine, i found it in the bottom of the door, what broke was the bracket that is attached to the window. is there a fix for that?
Old 02-23-2010, 08:59 AM
DAS1998's Avatar
not really.. you will have to pull the window out and drill out the rivets and install a new plate on the window. I have tried welding and rigging and it has never lasted. The job was not that bad. You do need a special rivet gun. I got rivets at fastenal.
should take an hour or so to get it done.
Old 02-23-2010, 10:55 AM
Thanks for the help, a buddy of mine at the local Goverment Motors is trying to get me the parts... hopefully it will be easy enough..
