Autozone ignition switch in car from old owner want to switch back to factory??
Ok, basically when I bought my camaro someone tried to steal it at one time when the old owner had it. They broke his old factory ignition switch. He replaced it with a auto zone switch that has no vats resistor in it. So, my security light stays on all the time. But, my car starts fine. He said everything was plug and play and he did not hot wire any wires or jump any. I looked under the dash and saw one wire that does not look factory as it's very loose. It's a large orange wire with two small wires in it.
I just dont know how he did it. I want to put a stock ignition back into the car with the vats system working right.
Now my question can I just purchase a a stock GM factory switch assembly with key and it's plug and play or do I also need the BCM? What all does it take? I know if I change the BCM I will also need new remote clickers.
