TB coolant bypass question on ls1
Old 02-22-2010, 08:38 PM
1qwkz's Avatar
Default TB coolant bypass question on ls1
is this even worth doing?
Old 02-22-2010, 08:47 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Moving this to Gen III External Engine
Old 02-22-2010, 08:51 PM
twpetry's Avatar
Short answer: no
Long answer: It really won't make a difference. If you want to do it, do it. If not, then don't.
/Thread
Old 02-22-2010, 09:12 PM
99LS1Bird's Avatar
its so easy its not a waste of time but if it does add power its mabey 1hp so just do it it takes a whole minute ha ha
Old 02-22-2010, 09:14 PM
01'SSLSX's Avatar
just do it, only takes a second. and anything to keep air inlet temps down is a good thing.
Old 02-22-2010, 09:15 PM
krissoto's Avatar
Every horse counts.
Old 02-22-2010, 09:22 PM
Duffster's Avatar
extremely insignificant... It passes through about 1/4" of the lower section of the throttle body and thats it. Less than 1" of total surface area inside the 'passage'. I removed mine for the purpose of reducing the possible leaks (2 less hose clamps) and changed the 2 hoses to 1....
Your call.
Old 02-22-2010, 09:26 PM
thegroup's Avatar
just that much less to mess with when removing the TB or intake
Old 02-22-2010, 09:33 PM
Ironxcross's Avatar
+1 to anything that makes these cars simpler to work on.
Old 02-22-2010, 11:01 PM
Mumbles's Avatar
Agreed.
Do it. It takes no time at all.
Old 02-23-2010, 03:29 AM
pheer's Avatar
do you jus get basic coolant (?) hose an replace it with the correct-ish length?
Old 02-23-2010, 03:35 AM
the_merv's Avatar
You can take the stock one and extend it over..that is how it worked for me on my Truck anyways..
Old 02-23-2010, 05:39 AM
slolt1's Avatar
what is u brazed the opining up on the tube and then caped the radiatior with a cap
any one done this
Old 02-23-2010, 06:40 AM
the_merv's Avatar
I would leave it as is, run it to the Radiator. That little system helps bleed the steam out of the Heads. It's not as delicate as a LT1, but it helps.
Old 02-23-2010, 09:52 AM
Duffster's Avatar
how does it help bleed? It's got no vent, no surface area to speak of. It's just kind of a high point (more likely to catch bubbles and hold them.
Old 02-23-2010, 11:54 PM
the_merv's Avatar
Pull that line off of the Radiator while the Engine running and tell me if it just holds bubbles..lol
Old 02-24-2010, 01:51 AM
dansean1's Avatar
Look at this way, it'll cost you a few bucks in parts, and doesn't heat up the air being sucked in. It's not worth too much thought.
Old 02-24-2010, 05:39 AM
White.Lightning's Avatar
Did you all cap the TB openings where the hose passed through?
Old 02-24-2010, 05:47 AM
the_merv's Avatar
^^You don't have to do that..some Coolant might come out when you take the lines off..but there is nothing there to worry about.
Old 02-24-2010, 05:52 AM
I just wanted to make 100% sure there wasn't a chance of a vac leak
Quick Reply: TB coolant bypass question on ls1
