Which weighs less?
Old 02-23-2010, 06:15 AM
fastlt1's Avatar
Default Which weighs less?
Which weighs less, a 85 s-10 or 88 mustang? Both with same engine and trans. Both vehicles stock besides the swap. Which will weigh less with gutted interior? Thanks.
Old 02-23-2010, 06:27 AM
Palomba's Avatar
my votes the fox body
Old 02-23-2010, 07:43 AM
fastlt1's Avatar
I'm bet the fox has better weight transfer and front to rear weight ratio, too. But anyone know any facts?
Old 02-23-2010, 08:22 AM
LS_10's Avatar
My 82 S10 with a LS1 weighs 2580
Old 02-23-2010, 09:25 AM
Lurk's Avatar
stock other than the swap? OR no interior, no A/C, no heat, fixed glass, no driver and no gas?
makes a difference.
That was a post bomb. Swoop in make a vague statement and wait to see what happens. hahaha
Old 02-23-2010, 10:33 AM
fastlt1's Avatar
Anyone know what the average ls1 swapped fox body weighs?
Old 02-23-2010, 10:47 AM
the_merv's Avatar
I'm thinkin the Car will hook up better..
Old 02-23-2010, 11:29 AM
2XR95Z28's Avatar
If your deciding on the two for an LS swap, go with the Fox, im doing a 95 s10 myself and i kick myself in the *** everyday wishing i woulda done the fox, more engine bay room, cheaper header options, k member that makes it alot easier, better rear suspension, and i would def say lighter... Wish i wasnt this far into the s10 otherwise i would have sold it for a fox... Just my opinion for you....
Old 02-23-2010, 03:46 PM
fastlt1's Avatar
I'm looking at a fox body and a s-10 both all ready have sbc 350 and turbo 350 installed. I thought I would run the sbc this season and do the ls1 swap next winter. Would it be a head start if it already is 350?
Old 02-23-2010, 04:51 PM
5-0stank's Avatar
Most likely, yes.
Old 02-23-2010, 04:54 PM
deelong4002's Avatar
I dont see how it would be a head start. Especially if you intend to use the LS1 with EFI, cause you would still need to redo the fuel system, and all the wiring for the PCM. IF you plan to carb the LS1, than maybe its a head start, but arent the mounts different?
Old 02-23-2010, 04:56 PM
and regarless of weight, the fox is going to hook 1,000,000 times better than any truck. You are gonna have to add weight to the back of the truck to get it to hook at all, or remove a ton from the front.
themachasy's Avatar
You can get the sbc mount adapters and just use them on the LS motor. It's easy.
Old 02-24-2010, 01:19 PM
LS_10's Avatar
makes a difference.
race seats in it 7 gallons of fuel motor and th400 trans big driveshaft with 1350 u joints for 9in. weld wheels stock brakes and drums on the rear no a/c it didn't come with it but am considering adding it stock steering gear box ummm factory dash that I cut the front out of and added a aluminum dash panel with guages Glass in all window's no cage yet it's coming ummmm harwood lift off hood 6in. roll pan in back factory bumper up front soon to be fiberglass with a carb'd LS1 and full exhaust with 20in. long mufflers.
Old 02-24-2010, 01:21 PM
LS_10's Avatar
Originally Posted by 5-0stank
Most likely, yes.
NOOOOO! cause then like me you have to fix all the things the person who butchered the first swap.
I thought the swap was easy. just my opinioin
Old 02-24-2010, 01:39 PM
s10-den's Avatar
[QUOTE=deelong4002;12938016]and regarless of weight, the fox is going to hook 1,000,000 times better than any truck. You are gonna have to add weight to the back of the truck to get it to hook at all, or remove a ton from the front.[/QUOTE]
That is absolutly not true.
Old 02-24-2010, 02:59 PM
Lurk's Avatar
I love it. That's not too stripped or anything.
Good info!
Old 02-25-2010, 11:10 PM
LS_10's Avatar
[QUOTE=s10-den;12942250]
so what does it take to make an S10 hook i'm having some issues right now with mine. I had bad shocks come to find out but the new ones are here now will install them tomorrow and back to the track this weekend. Oh and I removed the 2 lower leaf springs so hopefully it will do better
Quick Reply: Which weighs less?
