C5 Z06 Brake kit fit 18'' ADR M-Sports?
The title says it all. My stock rotors are warped finally at 14,000 miles (big shocker there). Since I'm going to have to buy new pads and rotors I thought about going with the C5 Z06 brake kit from UMI. I have the 18'' ADR M-Sports with a 8.5 width in the front with a 35mm offset. I just want to make sure this will fit prior to making the purchase.. I did a search and came up with nothing so any help/info on this would be outstanding. Thanks in advance..
Nick what's up man? I am dooms the swap I'm getting everthing off a wrecked zo6. I have 17' torque thrust 2's now and from the research I have they will fit under mine so you should be fine with 18's. You still have the same number?
Thanks for the feedback thus far. I want to use the C5 Brake Kit without spacers.. if I can't get that I'll probably just go with better rotors and pads.
Here is a list in a link on our site that shows you what all wheels that can not be used with with the C5 Kit.
http://www.umiperformance.com/catalo...rrvmaul2emiql0
If you have any other questions feel free to ask!
Thanks
Brad
This kit requires a minimum of a 17” wheel for clearance. All 1996 and newer 17” wheels will fit correctly with this kit. If you are running a different wheel set up please research fitment before purchasing.
From our research we have found the following wheels will NOT clear with the conversion kit, they may clear with the correct wheel spacers:
1. Enkei Win- 17” x 9.5”
2. 93-94 SLP Firehawk wheel- 17” x 9”
3. Borbet Type T- 17” x 9.5”
4. Forgeline RS Reverse Rim
5. Torque Thrust II
Application:
1993 - 2002 Chevrolet Camaro
1993 - 2002 Pontiac Firebird
Well that great for me and my torque thrust II so dose anyone have this combo? I hope so or I wastes about a week getting all this **** tougher.
5. Torque Thrust II
Application:
