Need a quick answer about HIDs
I just ordered the slim HID DDM kit, but i have a question about the bulb. I ordered the 9006, but is that only for stock headalights? Or would that work with my sonars I ordered it for? Because if not I need to call them and change my order before they ship it out. Thanks
edit- is it the H1?
edit- is it the H1?
I'd contact whoever you bought the sonars from and ask what bulb they use for the lowbeams... although I'm sure someone on here can answer your question. I'm almost positive they don't use 9006 though so you'll definitely need to change your order with DDM.
probably going to be a H1 or H3, im not sure i never looked at the sonars but those are the 2 common bulbs for projectors. check were you got the sonars from, they should be able to tell you. 9006 is only for the stock lights.
look at the bulb in it now.. it prob is h1 or h3. i had to buy a new pair of bulbs when i bought my new lights sense they were h3's
if they are h1's then i got 6000k bulbs here that have never been used if you'd want them cuz i bought them by accident instead of h3's haha
