67 Camaro ignition switch wiring?
Old 02-23-2010, 06:37 PM
Blue67LS2's Avatar
Question 67 Camaro ignition switch wiring?
I searched and I can't seem to find anything specifically addressing this subject. I am using a new harness from Current Performance and my orginal under dash harness and ignition switch. I have started the engine by connecting the pink wire manually, but can't figure out how to integrate this to work with my factory switch and under dash harness?
I've included a picture of the factory switch and the wires plugging into it. Any suggestions would be most appreciated. Thanks!
Old 02-23-2010, 08:47 PM
LS1MCSS's Avatar
Do you have any open(ignition) terminals on the fuse box? If so, you can use that for switched power to the harness. Just make sure it's hot in run and start, both.
Old 02-24-2010, 06:18 AM
Old Kid's Avatar
Default Ign switch wiring
Use your original ign switch to control a relay (or relays) which can then control whatever you need. This takes the load off of the switch and puts it on the relays. I believe that it's done this way on a factory LS harness. Study the factory diagrams found on this site.
Quick Reply: 67 Camaro ignition switch wiring?
