Just replaced DRL, bulb is good but it wont turn on??
Old 02-24-2010, 12:00 AM
USArmyZ28's Avatar
Default Just replaced DRL, bulb is good but it wont turn on??
Sup guys,
I recently replaced my DRL's, I know the driver side bulb is good because when I unlock the car via keyless entry both of the DRL's light up. But once I actually start driving around the driver side does not illuminate, when I turn my left turn signal on the green arrow just stays solid green and I can see my rear left turn light up but does not blink. Any ideas?
Old 02-24-2010, 01:03 AM
99huggerorangeZ's Avatar
sounds like a flasher,also check your DRL socket and make sure its not burnt inside.
Old 02-24-2010, 01:08 AM
Z28LS1camaroguy's Avatar
yea its ur Flasher relay thing under the dash, its easy to change once u find it lol.
Old 02-24-2010, 01:38 AM
USArmyZ28's Avatar
So where is this flasher thing you guys speak of lol
Old 02-24-2010, 01:41 AM
does your right side still work? if so just turn you car on(KOEO) and signal as if you were going to take a right turn and then listen for the clicking noise(on/off) of the relay underneath the dash.
