Fluidampr installation on LSX engine?
Hi guys,
I have an LS engine that I have put into a 70 Camaro.
We have removed the original belts and pulleys, and mounted a front runner kit from Vintage Air.
However, when we pulled off the original harmonic balancer we found that the crank "stub" had no positioning pin...
So how do we install the Fluidampr that was included in the Vintage Air kit?
Is the positioning irrelevant?
L:-)
Trondheim, Norway
L:-)
Trondheim, Norway
LS1Tech Premium Sponsor
Correct, the positioning will not matetr on this one. The ignition timing is all controlled through the PCM by a number of sensors on the engine. Just press it on and have fun!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
