Idle Issues: hanging at 12-1400
Old 02-24-2010, 06:36 PM
Wnts2Go10O's Avatar
Default Idle Issues: hanging at 12-1400
so i have a set idle of 850-900. nothing i do will bring it down besides timing but that caused a hang off throttle. (let off and it hangs for a sec then falls)
its a Torquer 2 (232/234 595/598 on 113) with a ported FAST with 95mm tb. the tps was already reset as was the set screw.
ugh
im kinda at wits end with this one.
Old 02-24-2010, 08:02 PM
Wnts2Go10O's Avatar
anyone?
Old 02-24-2010, 08:27 PM
flexusz28's Avatar
I recently had problems with the idle too. After doing the upper part of the engine including a BBK 58mm TB.
I found that the adjuster screw on the TB was completely loose and unscrewed itself to a point where the IAC couldn't compensate. I had 2000+ idle
Old 02-24-2010, 08:39 PM
Wnts2Go10O's Avatar
Old 02-24-2010, 08:45 PM
JonCR96Z's Avatar
Sounds like you need some better idle airflow tuning. Is it hanging while moving or sitting still?
Old 02-24-2010, 08:50 PM
Wnts2Go10O's Avatar
cold, it is somewht alright . once it gets warm (>150*) the idle creeps up and stays there. this is all sitting still
Old 02-24-2010, 08:51 PM
WeathermanShawn's Avatar
A little more information is required.
Like one poster said, is it hanging just at idle or when it moves. There are numerous airflow tables, but it sounds like you may just have too much desired airflow.
Do you have access to tuning software? There are many ways to tune that out (if that is the problem).
Old 02-24-2010, 09:06 PM
Wnts2Go10O's Avatar
at idle while not moving
theres quite a few diff airflow tables for idle. what about other tables like idle adapt max? note: i didnt have this trouble with the ls6 intake..lol. id love to find a tune with a similar setup as mine. im wondering how much i should knock down the airflow values for this thing? i do have hpt, ive been trying to tune out this weird hang and it was even worse right after the new intake (hanging at 2k) i just cant seem to shake the last 3-400 rpm
Old 02-24-2010, 09:11 PM
Oh, you have those pesky 'Idle Learning Tables', that also affect Idle Airflow.
But if it is Desired Airflow (the biggie), then your idle will come done as your ECT warms up. So, that would be the big clue. Or someone may have just set your desired idle speed too high.
Did this just start, or has it been this way?
Old 02-24-2010, 09:18 PM
Wnts2Go10O's Avatar
it came with he new intake. ive tuned out most of the hang as i said. ive set my desired idle is: 950 up to 111* then its 850. what should i do with the "learning tables."
Old 02-24-2010, 09:28 PM
Well most of the Idle Learning Tables don't normally kick in until your ECT is ~80C (176F).
It really sounds like your Desired Airflow Table is too high. Especially if it gets better as your ECT warms up..That would be my guess..
Old 02-24-2010, 09:33 PM
Wnts2Go10O's Avatar
other way around, its fine when cold, it creeps up when warm
edited the lil greater than sign
Old 02-24-2010, 10:12 PM
FRUSTRATED T/A's Avatar
post a log file, im sure someone will see something mybe.
considered an intake leak?
Old 02-24-2010, 10:15 PM
5.7 ute's Avatar
The warmer the engine, less desired airflow is needed, so lower it in the necessary temp ranges.
You might want to remove a bit of spark in the idle table as well to help it fall, or increase TF decay, decrease delay etc.
How are your IAC steps when this is occuring?
Old 02-24-2010, 10:32 PM
Quite odd..I would post up a log file. The desired airflow will almost always be less as ECT climbs. I take it never decays (the airflow)..It stays that way no matter what?
Old 02-24-2010, 10:53 PM
Wnts2Go10O's Avatar
ill hve to do another log because i didnt do idle logs wth a step count
ill do one tomm and post it up.
i know the engine needs less air when warm, ill try again tomorrow and see wht a new log/confg will catch. my current tunes base idle air above 111* is 12 g/sec.
Old 02-24-2010, 11:05 PM
5.7 ute's Avatar
I dont have HPTuners so I wont be able to look at it, but I am sure someone on here will. Logging the steps should give you an answer.
Old 02-24-2010, 11:09 PM
Wnts2Go10O's Avatar
the airflow increases because of the rpm. rpm and airflow should be going down not up. desired settles around 8-9 g/sec but im seeing 11-13. in rtt i even played with it and cut the base table to 5 jus to see what would happen. got nothin.
Old 02-24-2010, 11:21 PM
5.7 ute's Avatar
Is this ETC or cable?
Have you tried manually adjusting the IAC (if cable) with bidi controls? Ruling out a possible bad IAC stepper motor. Or even the idle port in the TB being incorrectly machined.
Old 02-24-2010, 11:42 PM
Wnts2Go10O's Avatar
yep. its not the IAC far as i can tell. hmm, i do hve an extra IAC though that i can try.
Quick Reply: Idle Issues: hanging at 12-1400
