'87 c10 with 5.3/4l60e
Old 02-25-2010, 06:37 PM
dec010974's Avatar
Default '87 c10 with 5.3/4l60e
this thread is to jomomma & ls1nova71. wake up. you both have c10's that r not in use. please, i repeat , please turn them in and take up knitting LOL. ls1nova71 stop playing with the popsicles. lol. the conversion is complete. here are some pics. ls1tech fam thanks for all the advice and pics. you all were an inspiring and informative.
Attached Thumbnails '87 c10 with 5.3/4l60e-87-gmc-c-10-road-5.3-4l60e-005.jpg   '87 c10 with 5.3/4l60e-87-gmc-c-10-road-5.3-4l60e-009.jpg   '87 c10 with 5.3/4l60e-87-gmc-c-10-road-5.3-4l60e-011.jpg   '87 c10 with 5.3/4l60e-87-gmc-c-10-road-5.3-4l60e-026.jpg   '87 c10 with 5.3/4l60e-finishing-touches-020.jpg
Old 02-25-2010, 06:43 PM
dec010974's Avatar
Default finished
here are the last pics. if more are needed pm or email me at dec010974@yahoo.com. again thanks alot ls1tech fam.
Attached Thumbnails '87 c10 with 5.3/4l60e-engine-bay-002.jpg   '87 c10 with 5.3/4l60e-engine-bay-004.jpg   '87 c10 with 5.3/4l60e-engine-bay-006.jpg   '87 c10 with 5.3/4l60e-engine-bay-008.jpg   '87 c10 with 5.3/4l60e-engine-bay-011.jpg
Old 02-25-2010, 09:57 PM
fptransport's Avatar
nice man.. congrats ,,, I am done with my swap as well ,, I got it done weds. and already have 250 miles in it. lol
Old 02-25-2010, 10:04 PM
ls1nova71's Avatar
If I lived in Miami, my swap would be moving at a faster pace. It's a cold *** SOB here right now!!! I'll be done by July if all goes well though. Congrats on getting your truck going.
Old 02-25-2010, 10:14 PM
white mayhem's Avatar
That really is a sweet ride bro! Nice job!
Old 02-26-2010, 05:59 PM
dec010974's Avatar
today i test drove my truck for the first time, with open exhaust. it seems like it had more power than my 383 stroker. yes i said it. the 323 (lm7) felt like it has more power than my 383. unbelievable. its a drive by wire unit. i barely touch the throttle and it felt like it wanted to break the tires loose.wow unbelievable.
Old 02-26-2010, 07:05 PM
Jimbo1367's Avatar
congrats
Old 02-26-2010, 08:15 PM
jomomma's Avatar
congrats man! i was up and running, but the 5.3 had some issues. it seems i put in all new parts exept the bearings and it cost me. so, now i have an ls1 w/ a g5x3 cam at the engine builders place getting finished.
Old 02-26-2010, 08:25 PM
buick455's Avatar
Default Headers
Which A/C mount, and headers are you using? And what all did you have to modify to make them fit?
Old 02-26-2010, 09:56 PM
yelo71454's Avatar
x2 what is that ac mount?? stock truck accessories? looks awsome.
Old 02-27-2010, 06:22 AM
dec010974's Avatar
Default 87 c10 with 5.3/4l60e
thanks for all the compliments. to answer yelo71454 & buick455 i used jba shorty headers and the kwik performance truck ac mount kit. the headers resemble the stock truck headers but flow much better. i chose the jba's to avoid notching the frame. everyone i spoke to with the c10 lsx swap had to notch the frame no matter what heads we used. i used the kwik performance kit because the fabbed tune port set up looked ugly. i also would've had to buy the ugly stuff to fab. on that note spend the money once. i know, i know, i shouldve waited til i found a good used l92 engine n tranny. ill post a video of shorty running later once im certain most bugs r worked out. keep on wrenching ls1tech fam.
Old 02-27-2010, 08:02 PM
dec010974's Avatar
Default update
hello ls1tech fam. what r you all doing for tuning of pcm's. vendors reflash pcm's for base tunes to get the lsx swap running, where do you go from there? as i drive the converted vehicle i noticed black smoke from the exhaust with black soot landing on the pavement, as i press the throttle. as i drive the vehicle, it hesitates and the excelleration is not crisp like the wife's 'burban. help me out. thanks in advance.
Old 02-27-2010, 08:16 PM
dec010974 did you hook up the obdII plug... if you did, run a scan it might be a 02 sensor.. good luck..
by the way.. I broke down for the first time and after going away as far as 90 miles from the house I broke down when I was going for a ride and I stop 2 blocks away from my house at my friends house and my starter went out oh well
also I 2nd you on the power ... I broke tires loose when going about 40mph already good ls pooowwwwaaaaa
Old 02-27-2010, 08:35 PM
Originally Posted by ls1nova71
If I lived in Miami, . It's a cold *** SOB here right now!!! ..
is that TEARS I see coming out of your eyes just kidding man...
I travel often to kc and joplin and I know it gets cold as ch*t up there...
Old 02-28-2010, 09:44 AM
gofastwclass's Avatar
I can vouch for this, I don't live too far from him. It's so cold I could either burn up all my project money and pretend to heat my poorly insulated workshop or I could stay inside and avoid being found frozen weeks from now.
Last time I was going to make a trip to the JYD, it rained... then turned to snow and back to freezing rain. WTF?!
Now if you southern cats would deliver some of your warmer weather to us...
Isn't it wonderful? I get sideways in second gear.
BTW, nice truck. Glad it's finally running, now go lay some rubber to celebrate!
Old 02-28-2010, 08:29 PM
dec010974's Avatar
Default pcm tuning
hello to all. r there any options to tuning or programming the pcm. the vendor disable the VATS and flashed the pcm to run in lsx swap form. while driving the vehicle i noticed black soot when i press the throttle. when driving the acceleration is not crisp.help me out ls1tech.
Old 02-28-2010, 09:31 PM
did you get a obdII , if so you can run a scan as mentioned.... it could be something as small as a 02 sensor////
gofastwclass,,,, you are not going to like what I am about to say but,,,, I was about to go do what you said "laid some rubber and celebrate" and when I was on the freeway I noticed a hesitation and smell burnt trans. fluid.. so I pull over and yeapp... smell burnt so I trying to take off again to get off the freeway and 1, 2 gear good,, but then it just slips from 2 to 3rd for a loooong time and well long story short tranny is out..... I am gonna see if the guy where I bought it comes thru with the warranty
Old 02-28-2010, 10:10 PM
dec010974's Avatar
Default damn damn damn
sorry to hear that. i guess we r both side lined. right now im not liking the way shordee drives. one guy i spoke(tuner) to this weekend told he likes the FAST stand alone system. yes i know, $2500. i think im gonna try to find someone locally to dyno/tune shordee for real world conditions. the stand alone system wont see my $2500, just yet. i forgot to tell that tuner this was a budget build.
Old 02-28-2010, 10:42 PM
montecarloss's Avatar
congrats on your build, truck looks nice and hopefully you get all the bugs work out.
Old 03-01-2010, 09:41 AM
I used brandon...the guy that put lt1swap together... I sent him my pcm, and i had it back with in the week.... runs great.... let me re phrase that... it ran great till the deep fried tranny lol... I talked to the guy where I bougth the transm from,, and he said he is gonna come pu my c10 to take to his transmission guys to check... I just dont know if he is gonna give me cr*p when he sees I dont have the drivers side plug anymore...
Quick Reply: '87 c10 with 5.3/4l60e
