ABS Inop and Spazzing Lights
Old 02-25-2010, 10:09 PM
fknsmshn's Avatar
Default ABS Inop and Spazzing Lights
Ok, so I know 2 things, low voltage makes these cars do weird things and my battery is questionable. Now heres whats goin on. I can get the battery charged enough to run the car for a little bit, and it idles as good as ever, but the "ABS INOP" light stays on the whole time, then the battery looses its charge and the car dies.
The next problem is, when I release the E-brake every light in the car (at least every light you can see form the drivers seat) flickers in unison and the BCM clicks with them. I know its the BCM because the dash is outa the car, so I can hold it up to my ear to listen to it. As soon as I reset the brake, it all stops.
So my question is, can all this come from havin a fried battery, or do I have bigger problems?
Old 02-26-2010, 12:22 AM
1_fast_gto's Avatar
sounds like your alternator isn't charging
Old 02-26-2010, 12:27 AM
fknsmshn's Avatar
Volt meter read high, as if it was charging a low battery.
I started the car with the charger set cranked up to 55 amps, or the jump start option then unhooked it. After that the car would only run for a short time. The alternator is only a year old. The battery is a POS.
Either way, would low voltage cause these two problems? I recall from somewhere that inadequate voltage would cause the ABS system to shut down, but now I cant confirm that.
Old 02-26-2010, 12:37 AM
1_fast_gto's Avatar
yes the abs can set low voltage codes, but im telling you if you have a good voltage source and the vehicle is running, you take that voltage source away and the car dies, it is more than likely your alternator. you could have a shorted battery, but who knows without actually testing it, pull the battery out and go have it tested at autozone or somewhere that tests batteries around you
Old 02-26-2010, 08:30 AM
mike13's Avatar
I still think you need a good battery even if the alternator is charging otherwise the car would run fine once you disconnected the charger. If I remember correctly the solenoids in the abs draws a fair amount of amperage.
Old 02-26-2010, 08:34 AM
mike13's Avatar
here's a post from 2005.
even if your getting good amperage check them, the first things that lose power are ABS/TCS, so try cleaning the terminals (and/or checking the battery/alternator) and making sure it's just not getting good contact, or your battery/alt are going bad.
awhile back I thought my alternator was going out, because I had the same problem, turns out it was just the terminals were so dirty it was getting rigid contact spikes hehe.
+ make sure your rear harness is plugged in correctly.
Old 02-26-2010, 11:27 AM
fknsmshn's Avatar
Alrighty, Ill check it out and see what I can find. Thanks guys.
Old 02-26-2010, 05:09 PM
fknsmshn's Avatar
Could my falshing light problem be caused by a bad BCM? Cuz now, for some reason, when I try to unlock the door with the key FOB the trunk unlatches. Never had any problem like this before. Also, could that be why the car dies after a minute of run time? Because the BCM doesnt recognize the VATS? Thats how I understood they work togather but I many be wrong.
Old 02-26-2010, 11:44 PM
racecar's Avatar
I would agree. Get a good battery and check out the alternator, look for corrosion on all terminals. If there is a problem with the bat or alt, everything else will be screwed until you get the correct voltage.
You may not have any other problem except bat or alt.
