Loud Noise when Nailing it!
From a slow roll or a dead stop, when I get on it. Feels like the Trans is hitting the floor board or maybe the TRQ arm is hitting! I have BMR lowering sprins, BMR TRQ-arm, lower control arms and Pan Bar. My questions is, because I`ve lowered the car is the trans mount flexing and causing it to hit the floor-board or what. Just curious! Thanks!
Is the poly trans mount really that bad? Just curious, I might have to get one since I run E/T`s at the track. There is supposed to be a stonger one at the GM dealership you can put on. Is this true and do you know which one. By the way how did you solve your trans mount problem? This is not going to go away!
