Fueling & Injection - stock truck fuel rail MAX hp?
mechanix565
02-25-2010, 11:10 PM
hey guys im running an aeromotive a1000 pump, boost referenced regulator,and 60# siemen injectors, im lookin at around 700 hp wit the turbo whats the stock truck rail good until? should i upgrade if so who makes a good rail for the truck intake?? thanks in advance
boostFedcivic
02-26-2010, 10:26 PM
That a1000 isn't going to keep up if you're running high base pressure. Got a built 331 stang in the shop that we put a gt4788 on 35 psi base pressure 13 psi of boost made 650 on our mustang dyno and was out of pump. Fuel pressure was all over the place at the higher levels. Customer bought a Weldon pump. The car went on to make 750ish on pump gas and 1024 on c16.
I'd upgrade pump if it's possible
RsSean
02-27-2010, 12:25 AM
I was always told at or around 500 to change rails
Chris05ssTruck
02-27-2010, 08:06 AM
When my truck made a lil over 425 it started to suck the rails dry. Could have been injector or a mix.
reamo04
03-01-2010, 09:53 PM
aeromotive specs their a1000 at 600lbs/hr at 45PSI, capable of 1000 crank HP.
Next step up is a magnafuel 4301 or 4101
speed inc makes a rail kit that should work, give em a call
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
