Doing a seat swap. What harness do I need?
I have a 99TA that came with the toggle switch style buttons on the seat and want to swap them out for the newer style ones.(the ones with the plastic looking gills on them.) my harness is different looking than the one that came with the new seats. The new seats also have this rubber looking cable coming out of the seat. Have no idea what harness I need. Thanks in advance.
here's a pic of the oem harness(white) with the new one(black) excuse the shitty carpet, its getting swapped as well
http://i60.photobucket.com/albums/h1...z/e84c12c1.jpg
the rubber hoses are for the air pump that pump up the lumbar support... tbqh im not sure why they run under the floor, cause theres a sack of stuff which i assumed to be the pump under the seat.
if you want pics let me know, i have my 00 seats out cause im swapping them.
I'm working from memory so I may mess this up a bit. I did the swap from my manual cloths to 6-way + lumber DS and manual + lumbar PS. What you need is the harness that interconnects the DS and PS seats. It will have 2 rubber hoses and a wiring harness. I think the air pump is under the PS side seat. The harness that comes from your floor will plug in to this harness and there will be a connector on the harness that will also plug in to the DS seat. I had to remove the console to get the the harness routed to the other side. I got the harness and hoses from a TA partout in the FS section for around $30. Hope this helps.
Edit:
Also check this thread if you can't find one. Guy did a writeup on making your own harness.
https://ls1tech.com/forums/stereo-el...wer-seats.html
Edit:
Edit:
Edit:
OLD
NEW
It should fit, as long as the a harness has the air hoses. Take a look at the plugs on the seats you are installing before you head to the junk yard, and make sure the connectors match. Again, may be worth checking the For Sale section for a part out first to save yourself the trouble.
