Drag Racing Tech
Bump stop?
Old 02-26-2010, 04:12 PM
INTENESS's Avatar
Default Bump stop?
I removed my bump stops for the bigger set of bogarts and tires im running.I want to pick up the bump stop that slides over the shock I was told a company called jounce makes them.Anyone using these andwere can you order them from?
Old 02-26-2010, 05:33 PM
JFM-jr's Avatar
Dave not to hi-jack the thread but did you get a manual rack?
Old 02-26-2010, 06:19 PM
INTENESS's Avatar
No not yet John have to find some who is capable of doing the alignment,thats what is holding me from pulling the trigger.Last guy i had do the alignment got the car all f'd up.
Old 02-26-2010, 06:25 PM
Restricted User
Zero4488's Avatar
Depending on suspension and use of the car I don't see why bump stops are needed. For a car that is primarily driven on the track or even on weekend (given you are not going Duke's Of Hazard style over speed bumps) I cannot see a need for them. I cut mine out awhile back in order to clear my 28x11.5's and haven't had an issue yet.....
Old 02-26-2010, 07:40 PM
INTENESS's Avatar
I hear ya just worried about possibly bottoming them out on launch,its cheap security,Im running qa1's so if I set up too soft then at least that takes the hit.
Old 02-27-2010, 06:55 AM
Race your car!
JL ws-6's Avatar
Dave leave them out, my car used to hit them and cause it to unload and spin, you don't want that when you hit the track this spring trust me.
I tried cutting the stock ones back, still didn't work, so I took them off, picked up a tenth in the 60 foot.
Worst that will happen is the tq arm will dent the tunnel a little, but after a couple launches it will clearance itself
When you gonna make your first trip? I'm in germany for work from the 4-17 to 5-1 this year But if you're going before that or after that, lemme know I'll come help. I can bring my fire suit in case you want someotn to take a pass in it , and I can sign off on your lic runs too (need to go get my physcial so I can renew mine)
Old 02-27-2010, 07:02 AM
INTENESS's Avatar
Okay thanx JL,you will be back by the time I want to go to the track.
Old 02-27-2010, 08:32 AM
LS1Tech Sponsor
Slowhawk's Avatar
I actually put a bump stop over the rear center section and hit's against a crossbrace on the frame.Didn't have one for awhile but on the highway I hit a dip and the rear smashed under the car. At the track my car lifts the rear on the launch so bottoming out there is not a problem.
Old 02-27-2010, 12:41 PM
Race your car!
JL ws-6's Avatar
Don mark that bump stop you have with a silver grease pen next time you run at the track and see if it's leaving a mark on the body, I didn't think my car was hitting the bump stops either until I marked it and found that it was, that's why I ended up taking them off.
My car doesn't lift, usually pulls the front a foot or so and carried it out 30 to 40 feet, rear doesn't really move at all other then down from the hit on the tires.
Every car's a little different, but mark the bumpstop, see if it actually touches it or not. If the car is hitting it, you may want to try removing it and see how it goes.
Old 02-27-2010, 03:14 PM
studderin's Avatar
I did spool, and summit rear shock at the same time that a removed the bumpstops. I had marks on them (got some paint on them when painting in BFH mod) were the paint was cracking and rubbed off form the axle tubes. But gaind about a tenth in the 60's no problems on the street so far.
Old 02-27-2010, 04:52 PM
AChotrod's Avatar
Damn you guys gained a tenth?? That solves that, mine are coming off. lol
Old 02-28-2010, 06:16 AM
Race your car!
JL ws-6's Avatar
I gained, because my car would leave, rear didn't really move, it pulled the front up then the rear would compress a touch as the front was coming up the the car was moving forward... it would hit the stops and unload the rear tires, causing them to spin. Not good.
Alot of cars will seperate at the hit, mine's never seemed to do that, rear generally doesn't move at all, unless I have the shocks set really soft because the track is absolute garbage... a common occurance in these parts.
When I have a good track the car will sett a 1.37 to 1.38 60 foot, which for a 625 rwhp setup @ 3350 lbs I didn't think was too bad, only problem is that it's not very often that the prep up here is that great, etown's prep for anything other then a big event can be iffy, island is usually o.k. and lvd has been o.k., it's been a good bit better then it was in previous years, but it's still not atco type prep.
Old 02-28-2010, 12:19 PM
AChotrod's Avatar
This was my first day out with the drag shocks, front needs some more dialing in but do the rears look like they are nailing the bump stops. Seems the car was unloading pretty hard and the front was bouncing around way to much. You can skip to .50
http://www.youtube.com/watch?v=RtZ0JXqBEHQ
Old 02-28-2010, 02:35 PM
airfix's Avatar
Mark them, and find out next time you go to the track.
Old 02-28-2010, 02:47 PM
AChotrod's Avatar
Ill check it out next time. It didnt bounce or unload like that with the stock shocks and springs.
