10 Second Club - Finally...10s Full Weight SS 6.0 L92s
RickClarke23
02-28-2010, 11:12 PM
Finally got a 10 sec slip. 1st bottle pass and only my 2nd pass on the new setup. Got the boot for no roll cage after the bottle pass so I couldnt make any adjustments to the tune.
Setup is
Full weight SS A4 (3820 with me)
Built 6.0l (lunati/diamond)
WCCH L92's
Pat G cam
Ported LS3 intake with LS7 Injectors
Nitrous outlet 90mm plate 150 jets
Racetronix Fuel pump w/rewire
Built 4l60e with Tci SSF 3800
Texas Speed 1 7/8 Headers with 18" Magnaflow Oval mufflers
Stock 10 bolt with 3.23's
Slip reads like this
60- 1.649
1/8- 6.998
mph-101.64
1/4- 10.902
mph-126.92
This was on Hoosier DRs and 17* of timing on pump gas. I wanted to get a baseline. I need to play with the Nitrous fuel jets as i was running rich at 11.2 and the plugs confirmed this and I also need to add about 4 more degrees of timing according to the plugs. However I may wait as the motor is built/gapped for a 300 shot so I probably will start pilling up very soon. I also need to get the hang of launchin this verter. it is pretty loose and probably will need to be tightend up on the bottle.
Here is a video
http://www.youtube.com/watch?v=vlU58u1O42o
Ls1Rook
03-01-2010, 01:57 AM
Sick cars congrats on the times
RickClarke23
03-01-2010, 02:04 AM
http://www.texasdragracing.com/races...ack-Action.wmv
Texas Drag racing got my car launching. Its the 1st one in the video....check it out if you want. Poor 10 bolt hauling my 3820Lb car to a crappy 1.65
