My 2000 WS6 wont start??PLEASE HELP!!!
Old 03-01-2010, 06:50 PM
pats'00WS6's Avatar
Exclamation My 2000 WS6 wont start??PLEASE HELP!!!
My WS6 started as a project car that my dad bought from the insurance company (minor front end collision) now its mine and almost done so last week i went out to work on the TA but the battery was dead and i thought no biggie so i hooked the jump pack and pulled it out of the garage. About 8-10 hours later i was done for the night and went to pull it back in battery was dead again so i got the jump pack but this time it cranked and cranked but wouldnt fire up so im thinking that i may have fried something in the computer system? Then today i checked it for spark and found that i had no spark so anyone i need help PLEASE!!
PLEASE HELP!!!!!
THX.
Old 03-01-2010, 07:07 PM
99LS1Bird's Avatar
make sure you are getting fuel and fire if so the best i can tell you is that the crank sensor is bad or a ground wire is loose somewhere in the front end from the wreck. i did a cam swap and had a dead battery right b4 first start and fought it for 2 days before i figured out it was the crank sensor
Old 03-01-2010, 07:26 PM
pats'00WS6's Avatar
Post
Yea someone else said it could be the crank sensor too but when i went to check for spark just to eliminate some possibilities i had found that i wasnt getting spark so thats why im so puzzled because i had it running perfect for quite some time before this happened its strange.
Old 03-01-2010, 07:48 PM
doublea87's Avatar
when you checked for spark did you pull off a plug wire on just one cylinder or multiple? i would atleast check two on each bank. most likely the CKP
Old 03-01-2010, 07:53 PM
pats'00WS6's Avatar
I checked 3 plug wires. Im hoping its not anything serious cuz im an ls1 loving senior in high school on limited funds right now. This car has every option and when it was wrecked it had 10,065 miles and thats what it has now and none of that stuff meaning pcm or electrical was touched so thats why im baffled. What is the ckp?
Old 03-02-2010, 10:03 AM
SSdimension's Avatar
+3 on crank sensor.
Old 03-02-2010, 10:18 PM
doublea87's Avatar
ckp is crank position sensor
cmp is cam position sensor
just a little heads up so yo dont get confused in other threads
Old 03-03-2010, 06:51 PM
joblo1978's Avatar
Ignition relay I bet. Replace it with the fan relay and try that.
