Stock o-ring for clutch master cylinder...HELP
Old 03-02-2010, 02:24 PM
JakeBrakeIH's Avatar
Default Stock o-ring for clutch master cylinder...HELP
Im putting in a M12 T56 into my 2000 Silverado and I lost the o-ring that goes onto the line that hooks to the clutch master cylinder. I tried calling the dealer but they can only sell me the clutch line and master cylinder which costs $166. Kind of expensive for an o-ring eh?
We've tried a bunch of different size o-rings out of a little o-ring service kit and no luck. I would get a little bit of pedal then the fluid would go past the o-ring. What Im wondering is, is the o-ring a little fatter if you will. Meaning is the ID the same as the o-rings we tried but the OD much bigger. I've tried searching but most of the threads are old and the pics aren't there anymore.
I took mine out over a year ago and I can't remember. I mean worse comes to worse, I will have to buy the new master cyl and line seeing thats the only thing holding me back from driving it, but I'd rather not.
Any help would be appreciated!
Old 03-02-2010, 05:22 PM
Well found some luck with McLeod. They are called McLeod Quad ring.
Heres a pic...
Ordered 5 of em at $2.50 and some roll pins for .50 cents.
Quick Reply: Stock o-ring for clutch master cylinder...HELP
