SLP 1" lowering springs
There are bunch of posts on here - do a search on SLP Bilstein/eibach. Basically, they do not lower an inch and several have complained that the front is too high but most are happy with the ride.
Hello
There are 2 cars here with those springs on Both SS and the rear seems to be lower than the front. But they do have a good ride quality and are a nice spring. Just my opinion. If you have any other questions feel free to ask!
Thanks
Brad
Thanks
Brad
Well I bought the springs anyways even after hearing tons of bad things about them. I'm very happy with the height. It is PERFECT and leaves me a little room for clearance once I get LT's and ORY. I'll post up pictures of before and after if anyone is curious.
i had a set of the eibach lowering springs and bilstein shocks, loved them. i had to let them go and go back with the factory height springs because of the turbo pipe that hangs pretty low. but you can't beat the performance of the eibach's though.
very nice i luv them, its good to have enough clearance instead worrying from dumbs and stuff
car still looks very nice,and i think the front and rear height are equal (as its looks)
Thanks Jason!
I didn't get a chance to get before measurements. I'll give you my after measurements though so you can compare them to how your car currently sits. Do you want them from the top of the wheel well to the ground?
Yeah I have stock shocks. I'll be replacing them soon the ride is a little rough but not too terrible. But I'm only 18 so I don't mind a rough ride as much haha
Thanks for the pics, looks good. Do you have a straight side shot of your car you could post? Some say the front is higher than the back with the SLP springs. I could not see that from your pics. I'm interested in these springs because from most accounts they ride very well. I would like a slight drop in ride height for my car, without a stiffer ride.
